How do I get this to work? I am assuming in the description field that when there are brackets at the end it is saying there is additional text to the ad. When I click on either the picture or the "View it", I get a blank page. Am I supposed to ad a widget or a plugin or something? There's nothing to select next to the ad description text that suggests I select something to activate this.
Hello, Please provide us your website url as well as the screenshot where you facing the problem. Thanks & Regards Yogesh Bhade
I am having the same problem. For me it is due to adblock that is install in goggle extension. It worked perfectly when i deactivated adblock. But Why only this page is blocked?
Thank you so much. It worked. I knew it was my computer because a friend of mine was able to open her view. But your question is a good one.
Hello, Sometime this occurs ad block may block images or java scripts or sometime it blocks links also. May be it can find keywords related to ad. http://support.getadblock.com/kb/other-problems/adblock-is-blocking-something-that-isnt-an-ad Thanks & Regards Pramod
