w3 total cache plugin - slider images disappear
Discussion in 'Infoway WordPress Theme' started by partex, Jun 30, 2014.
  1. partex
    partex New Member
    Activated w3 total cache plugin with Infoway theme (current). When I do, the slider images disappear.
    If I deactivate w3 total cache plugin, the images reappear.
    Searched a few other older threads but did not see a resolution.
    Is there a cache plugin that will work with infoway theme? If so, what do you recommend?
    Thank you
    www.bridgehillLS.com
    Our themes are compatible with almost all the plugin available in WordPress.org but there are thousands of plugin available on WordPress.org and some are regularly updating and some are not updated from many years therefore it is not possible for us to check every plugin with our theme, So you can search any alternative of that plugin.
    Or
    You can also contact to plugin related support forum. They will help you.
    Gourav Shrivastava
  3. partex
    partex New Member
    Thanks Gourav
    I'll follow up with plugin or look for another one that works.
