Web Page Footer moved off Alignment
Discussion in 'Cloriato WordPress Theme' started by jamsog, Jul 26, 2013.
  1. jamsog
    jamsog Member
    I updated the events calander on an existing web page and i now have the footer positioned off alignment
    can anyone help here
    You are using "The event calender" plugin which is creating problem.
    Use "All in one event calender" plugin it will work fine.
  3. jamsog
    jamsog Member
    if i use anothe rplugin- i have to redo all our calander events #???
    thats heavy work
  4. jamsog
    jamsog Member
    ive tried to look for the one you mentioned and cannot trace it - All in one event calendar - will this plugin recognise my existing events ??
  5. jamsog
    jamsog Member
    hello??? we have alot of events - if i change to another calander we loose them all
    not good dont you think
  6. Piyush
  7. jamsog
    jamsog Member
    thank you once again
  8. Piyush
  9. jamsog
    jamsog Member
    Not sure what you mean here?
  10. Piyush
    A plugin is creating the problem in the theme and we have done coding to make theme compatible with plugin.
    And if still you are getting problem then you have to contact to the developer of plugin.
    They will help you to solve your issue.
  11. jamsog
    jamsog Member
    yes ok
    i have emailed on another major problem we have
