Web View Vs Mobile View
Discussion in 'Local Business WordPress Theme' started by infolosophy, Jul 13, 2013.
  1. infolosophy
    infolosophy Member
    I'm having a sizing issue using the footer widgets where I can't get text information to appear similarly on standard web view and mobile. See www.hhiwindows.com...the middle footer widget. It has two addresses. To get the addresses to appear on separate lines on the web view I had to use 12pt font...On the mobile view to get the same effect I had to use 8pt font, which of course messes up the web view.
    I can't quite put my finger on the best way to fix it...
    Thanks.
    Paste the code given below in Custom CSS
    .footer_widget .textwidget span strong {
    font-size: 12px;
    .footer_widget .textwidget a {
    font-size: 12px;
    @media only screen and (min-width: 767px) and (max-width: 960px) {
    font-size: 12px;
    font-size: 12px;
    @media only screen and (min-width: 480px) and (max-width: 767px) {
    font-size: 8px;
    font-size: 8px;
    font-size: 8px;
    font-size: 8px;
    Adjust the values as per your requirement.
  3. infolosophy
    infolosophy Member
    After playing with the font sizes a bit , it worked like a dream....As always, THANKS!
