Wedding DJ Pro theme, change contact info
Discussion in 'General InkThemes Discussion and Feedback' started by dj3went, Oct 31, 2018.
  1. dj3went
    dj3went New Member
    I wasn't sure where else to post this question so apologies if this is not the right category. Is there any way to change the Contact Details for this theme? I can't seem to find where to change this, is it in Theme Options? Also, is there a way to change the social media icons itself?
  2. akbar92
    Greeting from InkThemes,
    You can check out this link of the video, I am attaching the video link below: https://screenpresso.com/=LUtZb
    This will help you to configure the widget area.
    If you need further help then let us know the same.
    Akbar
  3. dj3went
    dj3went New Member
    Hi Akbar,
    Thanks for the walkthrough video, was there supposed to be sound to the video? If so, I'm not hearing any. I was able to change the info in the widget areas but I didn't see where the social icons could be changed. Basically, I'd like to add an Instagram icon/field and take out some of the social icons. Where would I go to do that? Also, for the images on the slider, what are the photo dimensions of the original slide photos that came with the theme?
  4. akbar92
    See the video I am attaching below via link: https://screenpresso.com/=b0apg
    You will get to know how to change the social icons and there was no sound in the Screenpresso videos.
    Also, kindly send the below-mentioned credential details at [email protected] along with the thread link.
    We will add the Instagram option for you.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will do the needful.
    Akbar
  5. dj3went
    dj3went New Member
    Hi Akbar,
    Thanks for the video, info has been sent to add Instagram logo.
  6. akbar92
    Hello Welvin,
    We have successfully added the Instagram option in the theme.
    Kindly, check that out and inform us the same.
    Akbar
  7. dj3went
    dj3went New Member
    Thanks Akbar for adding the Instagram option, is it possible to make that logo as big as the Facebook one?
    I also would like to switch out the "weddingDJ" logo in the top left corner with the logo attached. How would I go about doing so?
  8. dj3went
    dj3went New Member
    Just remembered, I also see this "comments are closed" near the bottom of some of the pages. How/where do I go to get rid of that statement?
  9. akbar92
    To make the desired changes, just paste the code in the custom CSS section of the theme.
    Go to (Dashboard->InkThemes->Theme Options->Styling Option).
    div#commentsbox {
    Akbar
  10. dj3went
    dj3went New Member
    Thanks for the code, it worked!
    I had another question about how to replace the "WeddingDJ" logo in the upper left hand corner of the homepage with the logo uploaded. Is this something I can do or would you need to do it on your end?
    Thanks!
  11. dj3went
    dj3went New Member
    Apologies, thought of another question. Is there anyway to get rid of the "videobox" section? I don't have any videos or photos I'd like to add but I don't want it showing to others to upload a photo/video.
  12. akbar92
    You can change the logo from theme options, just have a look at the attached screenshot along with the thread and follow those steps.
    Also, let me know about which section you are talking to remove.
    It will be easy for me to understand via an edited screenshot.
    You can take the screenshot using https://www.screenpresso.com/
    Akbar
  13. dj3went
    dj3went New Member
    Thanks, I was able to add my logo! Attached is a screenshot of the section I'd like to remove.
  14. akbar92
    To make the desired changes, just paste the code in the Additional CSS section of the theme.
    Go to (Dashboard->Appearance->Customize->Additional CSS).
    To remove the main headings of this section use this CSS code:
    .featured-tagline-wrapper {
    To remove the videos or o hide them use this CSS code:
    .vidimg-container {
    Akbar
