Please take a look at http://www.alamedabiblechurch.org The head doesn't look right. Seems to be chopped off, and missing the top round part along with the bottom shadow. What I see is question marks or x boxes instead. Should like the beta version at http://www.topstepdesign.com/abcwebsite Any help appreciated.
Ok, I did that, and it fixed the original issue, but he is now getting the text for the Home Page Menu floating up in the middle of the home page. This is only occurring in Microsoft Explorer. I'm attaching a screen grab to show you what's happening.
Hello, Problem solved, download the theme again from the members area, your problem will be solved. Thanks.
Ok, I did that, and everything works, but the Alameda Bible Church logo shrunk down for some reason. Should like the beta version at http://www.topstepdesign.com/abcwebsite Please help...
Hello, We have checked you website and the header image is looking fine, also we are sending you the image for your refrence.
You are looking at and showing an image of the beta site. I need you to look at http://www.alamedabiblechurch.org -- it is the live site and looks like the image here:
Hello, Put the following code in custom css Appearance -> theme options -> styling options -> custom css Code: .header .logo img { width: auto; } This will solve your problem.
