Hi, I have major problem with my site all my listings are mixed up eg listing for business A is showing images/other details from business B etc. I have posted about it on here under somebody else thread who had similar problems and I have also sent details to [email protected] The last time I had response back was on June 1st and although I have chased up I have still heard nothing and in the meantime my site is still "broken". If you cannot mend theme it would be great if you could just let me know so I can search for another solution. thanks
Hi, Greeting from InkThemes, We need WordPress admin credentials to figure out the issue. Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will try to fix your issue. Regards, Akbar InkThemes.com
Hi Akbar unfortunately your response highlights part of the problem! did you not read my post? I have already sent all information to [email protected] and after the initial corresponding I have not hear anything from you since the 1st June! thanks Shaun
Hello, Greetings from InkThemes, For your information, your query is still in the pipeline, We will definitely check your site and fix the issues. As our team is busy in some other project our developers they will switch on your issues soon. I hope you understand, we will definitely fix this issue. Your patience and cooperation would be appreciated. Regards, Akbar InkThemes.com
We will fix it as soon as possible. Your patience will be highly appreciated, Warm Regards! Akbar InkThemes.com
It is well over a month now since I reported this problem initially to [email protected] and subsequently posted on here. It is very poor and shows a complete lack of "customer care" that no one has been in touch with a solution apart from messages on here that it will be fixed as soon as possible! Surely a month is long enough - Can you fix your theme or not?
