where are these areas?
Discussion in 'Infoway WordPress Theme' started by azgirl, Apr 28, 2013.
  1. azgirl
    azgirl New Member
    There are 2 areas in info way, I can't find where to change the text in one and the color or background image of the other...help a newbie please and thanks under-static-image.jpg info-bar.jpg
    1. For your first issue,
    Go to the Feature Settings panel (Appearance -> Theme Options -> Feature Settings) in your dashboard and put your text in the Feature Page Heading section.
    See the image given below for the reference.
    2. For your second issue,
    Go to the Styling Options Panel (Appearance -> Theme Options -> Styling Options) present in your dashboard and select your color scheme from the Theme Stylesheet section.
  3. azgirl
    azgirl New Member
    Thanks Piyush so much, this will help!
