Where can I edit footer data?
Discussion in 'Blackriders WordPress Theme' started by sunjeep8777, Jul 18, 2014.
  1. sunjeep8777
    sunjeep8777 New Member
    I really don't need any of this data in the footer, but if I did, where can I delete or edit this information?
    These are the default content of footer widget area.
    Go to the Appearance > Widgets panel in your dashboard and
    drag & drop Text Widget in the all Footer Widget Area and paste the code given below in the content section of that widgets.
    <p></p>
    This will remove the default widgets.
  3. thetrafficman
    thetrafficman New Member
    Thank you Piyush. Now how do I get rid of the header area?
    If you want to edit that text with your desired text....
    Or, if you are interested in removing that area...
    .header_container {
