Where does contact info in middle footer come from??
Discussion in 'Local Business WordPress Theme' started by squawk1200, Jan 17, 2014.
  1. squawk1200
    squawk1200 New Member
    Where does the contact information as shown in the middle footer section come from, where it appears to default to inkthemes? i cannot find anywhere (including in your documentation) for where to change that?
    You are talking about footer widget area, Go to the
    Appearance > Widgets
    Drag widgets and drop them in the first, second and third widget area, It will automatically display at your footer.
    Gourav Shrivastava
  3. squawk1200
    no, sorry, that does not work. I dragged the google map widget to the 3rd footer, entered the address location, and it still shows the default of inkthemes in India.
    also, how do you indicate the address for contact in the 2nd footer widget?
  4. Gourav
    For adding google map and your contact info use "Text" widget.
    Just go to the
    Drag "Text"widgets and add your contact info there and drop it in the second widget area.
    For Google map
    Just go to https://maps.google.com/ and copy your iframe embed code from there.
    then, Drag Text widgets and paste iframe code there and drop it in the third widget area.
    Gourav Shrivastava
