where is the second <body> ,</body> tags for the home page?
Discussion in 'Woodpecker WordPress Business Theme' started by sandradohn, Mar 24, 2016.
  1. sandradohn
    sandradohn Member
    Hi There, I am being told be the livechat supplier that I need to install a snippet of their code " right above the second <body> tag near the bottom on the home page. I would like to know where this is. Also, for other pages is the second <body> tag located in the same place?
    Please let me know. Thanks, Sandra
  2. Naveen
    Hello Sandra,
    Just access your theme files via FTP/cPanel and open header.php file contained in the theme's folder which is located in wp-content directory.
    There you can get and edit the required codes.
    Warm Regards!
    Naveen Kolhe
  3. sandradohn
    sandradohn Member
    Hi Navenn, Please let me know where the FTP/cpanel and wp-content directory are located. A screen shot would help. I am not a coder. Thanks, Sandra
  4. nitin
    nitin Guest
    We are not sure with your requirements.
    I would like to let you know that the <body> tag also works without </body>, so it would be better for us to understand and provide quick resolution to your query if you could just let us know in which part of the homepage you want the code to be placed/displayed.
    Upon confirmation of the exact location, we will provide you the necessary screenshot that will explain you how to place the code at the appropriate place.
    We would be glad to assist you.
    Nitin
  5. sandradohn
    sandradohn Member
    Hi There, Here is the instruction that I have about placing the code. I do want it to show on all pages. Thanks, Sandra
    I tried to paste it here but then I got a message that my message was invalid!
  6. nitin
    nitin Guest
    Hi Sandra,
    Fist of all I would like to inform you that the source code of the theme does not contain any second <body> tag. The only <body> tag that is available is in the header.php file in the theme. So, you can paste the required code at the starting of the tag in the header.php file itself and this won't make any difference.
    To learn how to add the code, Please follow the screenshot given below.
    Hope this helps...!
    Nitin
