Where to modify the Mobile width?
Discussion in 'Figero WordPress Theme' started by followme, Jul 15, 2013.
  1. followme
    followme New Member
    I've been using the Figero Pro version of the themes made available. Though the theme shows quite well on the desktop and iPad, it does not on a Smartphone. At least not to my satisfaction. It looks like there is margin on the left and right of the screen. I tried to fix this in the css file 960_24_col_responsive.css, but without any luck. What I'd like is to use a larger width then is provided at the moment. To show you exactly what I mean i've attached a screendump.
    Do hope you can help me out to change the width or at least indicate where to remove the margin.
    Rgrds,
    Willem
    It is not possible to increase the width of the theme because Figero theme is implemented on 960 responsive grid system, If we try to increase its width, It will break the layout of the theme.
