Hi, I've got this shortcode [ <?php rw_the_post_rating($postID); ?> ] i'd like to add to put in the relevant Blackbird template file that's responsible for showing excerpts. I just don't know which of the templates to put it in. Help please! Thanks!
Hello, I think you are using Rating-widget plugin, there is no need to use shortcode to display the star ratings on the particular post page, it will automatically display the star rating on the particular posts ,when you activate the Rating-widget plugin.
