Hi, I hope you can fix an issue with my site. I updated the theme to Startpoint 1.2 and I am not sure if this is the latest version. For some reason when I resize the window from desktop to mobile it changes from Black background to pink? I also have this annoying white gap that is is between the slider and header. Can this be fixed in anyway? Many thanks. Mike
Hi, Greetings from InkThemes, To make desirable changes, just paste the code given below in Custom CSS section. (Dashboard->Inkthemes->Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: @media (max-width: 767px){ .mean-container .mean-bar { margin-bottom: 0px; } } .menu-wrapper-bg { background: #2e2d26; } div#page { margin-top: 0px; } Hope this helps...! Thanks & Regards! Akbar InkThemes.com
Hi Akbar, Thanks, the colour issue is corrected but I still have a gap. I've sent an email to the support inbox. Would you mind taking a look. Thanks, Mike
Hello, We have successfully received your credentials and is being forwarded to our developers, we will get back to you with a positive response ASAP. Your patience will be highly appreciated, Warm Regards! Akbar InkThemes.com
