White screen when going to admin
Discussion in 'ColorWay WordPress Theme' started by biobalanceskin, Nov 28, 2012.
  1. biobalanceskin
    biobalanceskin New Member
    I built a web site using colorway free theme a couple of years ago. A couple of days ago, I upgraded to colorway pro, and everything seemed just fine. While still in the admin area, I opened a new tab and brought up the site - all looked fine (except for some color changes, which I had expected). The problem occurred after I quit my browser. After quitting my browser, I was unable to log in (www.mysite.com/wp-admin). Just brings up a blank white screen
    The only way I was able to log in was to ftp to the server and change the name of the theme directory from colorwaytheme to colorwaythemex. After renaming the theme directory, I was able to log in to the admin area without issue. Once logged in, I renamed the theme directory back to colorwaytheme and everything seemed ok again - until I logged out of admin, and tried to log back in - same blank white screen.
    I googled the issue, and tried a number of suggestions I found (removing whitespace from wp-config.php and functions.php files) I checked my php error logs - nothing. Any idea what could be causing this problem?
  2. biobalanceskin
    I guess i should mention that the site itself works just fine - whether logged in or not - the site itself works flawlessly. I just can't get to admin. And I have tried using several browser/OS combinations...
  3. admin
    admin Admin
    India
  4. biobalanceskin
    Email Sent! Thanks.
