Widget conflict with Home Page Slider
Discussion in 'Elite Pro WordPress Theme' started by bizzyboy, Dec 9, 2013.
  1. bizzyboy
    bizzyboy Member
    Hi
    I am using a standard 'Text' widget to display a data collection form in the right hand sidebar of my site but when I use the Widget the Slider Image and its Description disappears from the Home Page.
    For example you can see the data collection form in the right-hand sidebar on one of my inner pages here:
    goldrothiraplans.com/gold-type-allowed-in-a-gold-ira
    You can also see the data collection form on the Home page but the Slider Image and Description is missing. When I remove the Widget the Slider Image and Description re-appears.
    Is it possible to get the Slider to display correctly on the Home Page whilst also using the data collection form within the Widget?
    Thanks - Paul
    Our theme is compatible with almost all the plugin but there are multiple plugins available in WordPress
    therefore it is not possible to check every plugin with the theme, Search alternative of plugin from WordPress.org
    and installed it, This will solve your issue.
  3. bizzyboy
    bizzyboy Member
    Hi Piyush
    Thanks, but as my first message said "I am using a standard 'Text' widget" i.e. it is a Wordpress.org Widget and not a Plugin.
    Any help you can provide so that the standard Text Widget works would be appreciated.
    Thanks. Paul
  4. Piyush
  5. bizzyboy
    bizzyboy Member
    I have emailed your support with the requested information. Thanks.
  6. Piyush
