Widget on the right side
Discussion in 'Cloriato WordPress Theme' started by netspezi, May 16, 2014.
  1. netspezi
    netspezi New Member
    Hello
    I have a site www.specialdive.at. If I go to the point of Calendar here is on the right side several widgets. Partners, items, etc.
    I would like to illustrate the calendar bigger and therefore would need the space of the whole page.
    I would like to be able to define these per page widget. if so how does it work
    thank you very much
    michael
  3. netspezi
    netspezi New Member
    Hello
    I want delete the right sidebar when i go a site i see on the right site Archive and Categories (look in the file)
    This i dont want see. I need this place for the content from the website
    Is this posible ?
    Thx
    mike
  4. Gourav
    You are talking about sidebar widget area, Go to the
    Appearance > Widgets
    Drag widgets and drop them in the primary and secondary widget area, It will automatically display at your sidebar.
    Also check the link given below
    http://www.inkthemes.com/how-to-use-widgets-in-wordpress/02/
    I hope it will help you.
    Gourav Shrivastava
  5. netspezi
    netspezi New Member
    Hello :)
    No i want no widget on the right side.
    I need place on the right side.
    when i go to the Appearance > Widget there is no widget in dhe Primary area.
    Go to my side http://www.specialdive.at/termine-2/ and you see on the right side
    search ( why? ) archiv (why?) Categories (why?)
    Thx
    mike
  6. Piyush
    Go to the Pages > All Pages panel in your dashboard and edit those pages from which you want to remove the right sidebar and then
    select the "Fullwidth Page" template from Page Attributes section.
    This will remove the sidebar from that page.
    See the image for reference.
  7. netspezi
    netspezi New Member
    Yes Yes Yes
    Thx !!!!!!!!!!
    Merci
    Mike
