Hello, there are basic widgets in this theme. but how can i make a differtent widget per page? that would be super. hope somebody can help
It seems you would like to use different widgets on different pages. I think the below plugin will be helpful for you. https://wordpress.org/plugins/dynamic-widgets/ Please install it on your WordPress and configure your widgets as per your needs. Regards! Naveen Kolhe InkThemes.com
thanks, but how can i say that I want a google maps widget on for example our contact page where now is a default primary widget?
Hi, It would be better for us to understand your query with the help of some edited screenshots of the concerned areas of your site. So that we can deliver you an exact and appropriate solution to you, Looking forward to hearing from you soon. Thanks & Regards! Akbar InkThemes.com PS: You can create your screenshots using screenpresso (http://www.screenpresso.com).
Hi, Please, use widgets in the Primary or Secondary Widget Area, go to (Dashboard->Appearence->Widgets), just follow the attached screenshot. Do let me know if you need further help. Regards, Akbar InkThemes.com
