Widgets Category Issue
Discussion in 'VideoCraft WordPress Theme' started by adnanhmd6, May 24, 2015.
  1. adnanhmd6
    adnanhmd6 Member
    Bangalore
    Hi
    In my widget, i have added category widget but whenever i check display as dropdown i get the following error. But if i am not checking that it works fine. Its in localhost cant give the access. I have attached the following files.
  2. adnanhmd6
    adnanhmd6 Member
    Bangalore
    Would be great, if i get some solution or suggestion.
  3. sameerwalkar
    sameerwalkar Guest
    We have forwarded your query to our technical team.
    Will getback to you with possible solution.
    Thanks for being patient and cooperating with us.
  4. adnanhmd6
    adnanhmd6 Member
    Bangalore
    Hi
    I been nearly a week time. Still no solutions, its just one drop-down issue. Could be great if that issue gets resolved asap.
  5. Sobhagya
    Sobhagya Guest
    I am glad to inform you that- Your issue has been fixed.
    That was a theme related issue so we have fixed and updated it to members area.
    So request you to kindly download and do the fresh installation with updated theme.
    Warm Regards!
    Sobhagya Sahu
    adnanhmd6 likes this.
  6. adnanhmd6
    adnanhmd6 Member
    Bangalore
    Hi
    It would be great, if you could specify which all files you have made the changes. Since i have customize few files. Again redoing will be time consuming.
  7. Sobhagya
    Sobhagya Guest
    Hello Adnanhmd,
    Kindly follow the file path in which we have made changes:
    Kindly copy and replace category_widget.php file and paste it in your current theme folder.
    Hope that will solve your issue.
  8. adnanhmd6
    adnanhmd6 Member
    Bangalore
    Thanks appreciated. (One suggestion could be great if you could include "All" as a option at the top of the drop-down).
