Hello, I have tried putting a small form on both the Primary and Secondary widget area but it's not appearing. The footer widget edits are just fine. Any ideas as to what I've overlooked? Thanks, Gary
I have checked our theme, it is working correctly with the form code in the Primary and Secondary widget area. Do let us know your website link so that we can provide you the exact solution.
http://www.studentdebtplan.com I have the form on the http://www.studentdebtplan.com/application-form/ but I can't get the small version of the form to show up either on the home page or the widgets. Thanks for the help.
Download the Contact Form 7 plugin from the link http://wordpress.org/extend/plugins/contact-form-7/ and install it in your dashboard. Use its feature in the widget area.
I have still tried everything to get the form to show up on the home page and still no luck. I do not like the Contact 7 forms because I'm trying to make a converting landing page and the form needs to have html attached to it.
I have seen your website and i think you have resolved this issue by yourself. If it is not resolved then please do let me know your issue more clearly.
Hello, To make Your Contact Form Better On Your Website You can use "formget-contact-form" plugin, which will help you to make your contact form easily and simple. Download it from the link given below. http://wordpress.org/plugins/formget-contact-form/ You just need to register on FormGet, create your form by clicking on the fields and embed the code on your website at any page, post or widget. You can easily place the contact form on every page of your website which will increase the user interaction. You will be able to manage entire communication from a single place between you and your visitor. It will be easy for you to provide support, feedback to your users. We recommend you to try this new contact form solution on your website. Hope it will meet your requirements. You can easily replace the existing contact form with this new one. Let us know your feedback
