Widgets not showing
Discussion in 'Appointway WordPress Theme' started by webnimo, Sep 5, 2013.
  1. webnimo
    webnimo New Member
    I' using the Appointway theme (1.0) and I' ve almost done all necessary customization except the footer. The widget column right is not showing up so I can' t drag and drop the widgets to customize the footer.
    vybedoug
    Deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s).
    It will work. If not then please provide the following information listed below.
    Thread Link: http://www.inkthemes.com/community/threads/widgets-not-showing.7181/
    Your Website URL:
    WordPress Username:
    WordPress Password:
    I will check and resolve your issue
  3. webnimo
    webnimo New Member
    Thanks a lot Nitesh. It worked like magic. I found the culprit:)
    Cheers,
    Douglas
