will upgrade of theme overwrite our own translations?
Discussion in 'Infoway WordPress Theme' started by superevent, Jan 19, 2015.
  1. superevent
    superevent Guest
    We were recommended upgrade our theme wich should help with the problems we have with the contactform.
    But we have made some changes in the .php file, mostly translations to Danish. Will a upgrade of the theme owerwrite the translations and other coding made in the .php file?
    Is it possible to only make a update of the contact form?
    Bests Mikkel, SuperEvent
  2. Pramod
    Pramod Guest
    Hello Mikkel!
    Are you using theme default form?
    If yes then download afresh copy of theme and replace only contact page template file.
    Please make a backup of your customization before updating because it may loss your customization.
    Pramod
