Woo Commerce Plugin for Cloriato Theme
Discussion in 'Cloriato WordPress Theme' started by gabriellastrano, Oct 23, 2013.
  1. gabriellastrano
    gabriellastrano Member
    Hi, Is the Woo Commerce plugin compatible with the Cloriato Theme? I've tried installing it 6 times now without success.....Please help as I would prefer to use Woo Commerce than WP e-commerce.
  2. gabriellastrano
    Regarding the above thread, I have tried downloading the WooCommerce zip folder and uploading it to the plugins, and I've also tried installing it through the wordpress plugin search. Please see screenshot. Contrary to what it says, I cannot find WooCommerce within my installed plugins.
  3. Gourav
    You can use "Wp- e-commerce" plugin. Download it from the link given below.
    http://wordpress.org/extend/plugins/wp-e-commerce/
    And Cloriato Theme will work fine with this plugin. Use fullwidth page template for product and Checkout pages.
  4. gabriellastrano
    Hi Gourav,
    I want to use Woo Commerce instead of WP e-commerce. I have since managed to successfully install the plugin, but will it work ok with the Cloriato theme?
  5. kimharp
    kimharp New Member
    I have the same question--does anyone know if Woo Commerce will work with Cloriato?
  6. Nitesh
    Yes you can use "Woo Commerce" plugin with "Cloriato theme". It will work fine.
    Nitesh Raghuwanshi
