Hi heres my problem: colorway & woocommerce the cart doesn't work www.sweetcoffeepirates.com woocommerce works without problems on wp twenty twelve so whats the problem thanks for your help
Colorway theme is comfortable with Woocommerce plugin. We have checked your site, Selected items, moved to cart and then checkout through Paypal, All is working fine. Please specify exactly where you are getting issue.
Hi...So if you say everything works. I dont know! it isn´t possible to choose between 250g 500g & 1ooog and also to fix the choice between the kind of grind. and than to put it in the cart... helpless but hopeful thanks
