This theme doesn't seem to be compatible with WooCommerce... I tried using the workaround from here: https://docs.woocommerce.com/document/third-party-custom-theme-compatibility Where I copied the page.php, renamed it woocommerce.php, and replaced the loop - this still doesn't display correctly, though... The sidebar is back to the side (instead of at the bottom), but the footer doesn't display at all. Here is what I did to the PHP file... I replaced this code: PHP: <?php if (have_posts()) : the_post(); ?> <?php the_content(); wp_link_pages(array( 'before' => '<div class="page-links"><span class="page-links-title">' . __('Pages:', 'businessgrow') . '</span>', 'after' => '</div>', 'link_before' => '<span>', 'link_after' => '</span>', 'pagelink' => '<span class="screen-reader-text">' . __('Page', 'businessgrow') . ' </span>%', 'separator' => '<span class="screen-reader-text">, </span>', )); endif; ?> With this code: PHP: <?php woocommerce_content(); ?> I'm not sure why the theme doesn't just work with something as standard as woocommerce - but any help you could provide to get this displaying correctly would be greatly appreciated! Thanks...
Hello, I have got your concern and would like to check your site. It should work. Kindly, share your WordPress admin credentials at [email protected] along with this thread URL: WordPress site login URL: WordPress admin username: WordPress admin password: I will check and do the needful. Warm Regards! Naveen Kolhe InkThemes.com
