WooCommerce issues
Discussion in 'Compass WordPress Theme' started by smarta, Feb 26, 2017.
  1. smarta
    smarta Member
    I am using Compass for a woo-commerce site at http://dantefootwear.com.au/
    I have a few questions I hope you can help with
    1. how do i make the product pages full width pages?
    2. I need to charge the colour of the "rollover state" of the pull down menus
    currently the rollover is white text on a white background
    whats the css code to change that
    3. I would also like to change the text colour for " cart_list product_list_widget " in the footer widget
    the wording says "No products in the cart." but is in dark grey on a black background - it needs to be white text so it can be seen
  2. smarta
    smarta Member
    I just noticed that you guys had added a lot of css styling code for me a while back
    so I have emailed the log-in details to support@ as it may be helpful for you
  3. smarta
    smarta Member
    can I get a reply on this please
  4. nitin
    nitin Guest
    Hope you are doing good...!
    You would be glad to know that we have made the changes to your website as per your requirements.
    Kindly check and acknowledge us for the same.
    Regarding the "rollover state", we were unable to get the area in your theme which you were concerned about.
    Could you please provide us some edited screenshot of your requirements/concerned area, so that we can assist you accordingly?
    Looking forward to hear from you.
    Nitin
  5. smarta
    smarta Member
    hi
    attached are two screen shots showing the 2 problems
    1. menu rollover
    2. car widget text colours (underlined red) need to be lighter so they can be read
  6. nitin
    nitin Guest
    You would be glad to know that we have fixed the issues as per your requirements.
    I just visited your website and found that everything is displaying properly as they must be.
    It must be the cache issue on your browser. For once, try refreshing the page by pressing Ctrl+F5 and then clearing your web browser's cache.
    If the problem persists, do let me know.
    Nitin
  7. smarta
    smarta Member
    brilliant - thanks !
