WooCommerce not activating.
Discussion in 'InkThemes-Support Working Hours' started by garyfmoody, Jun 10, 2019.
  1. garyfmoody
    garyfmoody New Member
    Just purchased a developer version. Installed fine. Went to activate a template and the WooCommerce plug-in isn't activating. Can't install the site without. WooCommerce seems to be also blowing up my Elementor Pro install. Is there a way to install the template without the WooCommerce plug-in?
  2. shemaela21
    shemaela21 Guest Staff Member
    Greeting from InkThemes,
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    We will do the needful for you.
    Shemaela
