woocommerce plugin compatible with colorway theme
Discussion in 'ColorWay WordPress Theme' started by aplusa, Feb 10, 2014.
  1. aplusa
    aplusa Guest
    Hello there,
    is the colorway theme compatible with woocommerce plugin or do you use any other similar plugin?
    Thank you in advance!
    Our theme is compatible with almost all the plugin but there are multiple plugins available in WordPress
    therefore it is not possible to check every plugin with the theme, Search alternative of plugin from WordPress.org
    and installed it, This will solve your issue.
    I would personally suggest you to try WP e-Commerce plugin.
    Download it from the link given below and install it from the Plugins panel (Plugins ->Add New ->Upload) in your Dashboard.
    http://wordpress.org/plugins/wp-e-commerce/
    This will work fine with this theme.
