Woocommerce sidebar issue
Discussion in 'ColorWay WordPress Theme' started by filippochiocchini, Jul 26, 2013.
  1. filippochiocchini
    filippochiocchini New Member
    Woocommerce plugin might be conflicting with the theme , We always try best testing with almost all the plugin but there are multiple plugins and there updations are available in WordPress. Therefore, it is not possible to check every plugin with the theme, You can use WP e-Commerce plugin it may work fine with the theme.
    So, remove the Woocommerce plugin from the theme and
    download WP e-Commerce from WordPress.org (http://wordpress.org/plugins/wp-e-commerce/)
    and install it from the Plugins panel (Plugins ->Add New ->Upload) in your Dashboard.
    I hope it will helps you.
    Thanks for your cooperation.
  3. filippochiocchini
    I understand but woocommerce is perhaps the most widely used e-commerce plugin so it deserves to be compatible with the theme
  4. Piyush
    Firstly Woocommerce plugin was working fine with our theme but now it is conflicting with the theme and creating some issues that are not seen before i think after updation of plugin some files has been changed and they are creating this issue, We always try best testing with almost all the plugin but there are multiple plugins and there updations are available in WordPress therefore it is not possible to check every plugin with the theme, You can use WP e-Commerce plugin it may work fine with the theme.
    Download WP e-Commerce from WordPress.org
    Thanks for your patience.
    filippochiocchini likes this.
  5. filippochiocchini
    i'll try and let you know, ty
