Changed my products to be variable and now the add to cart button is not showing up. Please advise on how I can fix this.
Hello, Paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: .single_variation_wrap { display: block; } It will resolve your issue. Thanks & Regards Yogesh Bhade
Also noticed for simple products that the + - buttons are no longer there. Please advise on how to fix. Thanks!
Hello, 1. Paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: .single_variation_wrap { display: block !important; } 2. It seems that + - button code in not present in your woocommerce plugin so please reinstall woocommerce plugin. It will resolve your issue. Thanks & Regards Yogesh Bhade
I uninstalled and reinstalled woocommerce and still no + -. Also lost a bunch of pages: Shop Base: #6 - /?page_id=6 Cart: #7 - /?page_id=7 Checkout: #8 - /?page_id=8 My Account: #9 - /?page_id=9
Hello, Try to install fresh theme and woocommerce plugin, this will resolve your issue. Thanks & Regards Yogesh Bhade
Hi, I had the same problem so I made the suggested changes which worked and the add to cart now appears - however, when you click on it it does not add it to the cart it here is an example http://239bike.co.nz/?product=avanti-2014-forte-womans
Hello, 1. This issue maybe because of plugin. So please deactivate all plugins to see if this resolves the problem? If this works, re-activate the plugins one by one until you find the problematic plugin(s). 2. Use latest version of WooCommerce plugin i.e. Version 2.2.8 Thanks & Regards Yogesh Bhade
Hello, We have got your concern, please send us your WordPress dashboard login details also the link of this thread at [email protected]. so that, we can have a look over the issue in details. Your website link: WordPress username: WordPress password: This thread link: http://www.inkthemes.com/community/...riable-product-not-showing-add-to-cart.14382/ Note: When your issue get resolved, you can change your password. Thanks & Regards Yogesh Bhade
Hi, this has been sent a few days ago however I have not had a reply and the issue has not been resolved. Can you please confirm you received the information. Thanks, Rochelle
Hello Rochelle, We didn't receive any mail from you, please resend us at [email protected] Thanks & Regards Yogesh Bhade
Hello Rochelle, In your site all "Single Products" are adding in CART. But all "Variable Products" are not adding in CART, So please contact WooCommerce Support and learn how to make able variable product to add in CART. They will resolve your issue. Thanks & Regards Yogesh Bhade
