Hello can I remove the border on the feature images and not have them expand in size? Thanks. http://www.reachops.com/ - the images are 175 pixels wide. Thanks!
Hello, Greetings from InkThemes! Could you please provide us some edited screenshot of the concerned area, so that we can assist you accordingly..? If you are unable to create screenshots then you can use www.screenpresso.com that will help you to create screenshots. Thanks & Regards! Priyanka InkThemes.com
I apologize the border on the images was my error, but I am still having the issue of them displaying too large - they are 170 pixels but are stretching much larger
Hello, I have checked you site and didn't get any issue as you stated above in desktop screen but yes that issue appears on the smaller screen... So for that, please paste the code given below in Custom CSS section (Appearance -> Theme Options -> Styling Options -> Custom CSS) of your dashboard. Code: @media (max-width: 767px){ .feature-page-wt-thumb-container img { width: 70%; } } Note: change the numeric value as per your requirement. Kindly check... Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Hello, Change width percentage as per your requirement... Hope you will get it... Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
Hello, I added the code to the custom css and changed the percentage code to several numbers (down to 10%) and no changes seen - the feature images are still expanded too large
Hello, Would you please clear your cache and check after that...? Thanks & Regards! Priyanka InkThemes.com
Hello, these images are still expanding. The 3 round images are 175 pixels wide, but look much larger. Are they correct in your view? Thanks. www.reachops.com
Hello, Please try below code for once and change value according to you.. Code: .feature-page-wt-thumb-container img { width: 85%; } And if still you are with the same issue, please share your dashboard details at [email protected] along with this thread link so that we can figure out the issue and able to resolve that... Looking forward to your reply. Thanks & Regards! Priyanka InkThemes.com
Hello, Please paste the code given below in Custom CSS field of your dashboard and change numeric value as per your requirement.. Code: .feature-page-wt-thumb-container img { margin-left: 67px; } Hope it will resolve your issue Do let me know if you need more assistance, Thanks & Regards! Priyanka InkThemes.com
