Hi I read through the forum posts and removed the video by adding code to the custom CSS: .vidimg-wrapper { display: none; } The Bottom Feature Area has now moved up to cover the the Three Column feature. Is it possible to add text below the slider and above the Three Column feature?
Hello, It would be better for us to understand your query with the help of some edited screenshots. Please share some screenshots of the concerned areas of your site. So that we can deliver you an exact and appropriate solution to you, Looking forward to hearing from you soon. Thanks & Regards! Akbar InkThemes.com PS: You can create your screenshots using screenpresso (http://www.screenpresso.com).
I think that a better approach might be to use another theme rather than customize this one too much. Thank you for your reply.
