Woodpecker Slider Images order
Discussion in 'Woodpecker WordPress Business Theme' started by marketinggal, Sep 16, 2014.
  1. marketinggal
    marketinggal New Member
    Everything was working yesterday when we added the images to the slider under appearance > theme options > slider settings. Today we had to replace the slider with new images, and now the order is not correct. We have tried to remove the image, save and then upload again. Can you please help? We have checked all the coding to make sure it is correct. So, in other words, the slider that is supposed to be in the #2 position is coming out last. The website is not published yet. Thank you.
  2. Pramod
    Pramod Guest
    Please remove all slider images and then upload one by one from starting in slider setting according to your requirement.
    Pramod
  3. marketinggal
    Hi Pramod, Thank you for responding.
    I did that per your instructions. I uploaded one at a time and saved after each one. And this is what happened.
    The first one was fine.
    The the second one that was supposed to be in the #5 slider position, was showing in the #2 position.
    The third one was supposed to be in the #4 slider position.
    The fourth one was supposed to be in the #3 slider position.
    And the fifth one is supposed to be in the #2 position. Confusing, right?
    Once I tried it backwards, it worked. I ended up putting the one that was supposed to be in the #2 position as the fifth one, etc. Totally backwards - and it worked. But I don't want to deliver it this way to my customer. Any ideas?
    Thank you so much!
    Jo
  4. Pramod
    Pramod Guest
    Thread Link:
    Your Website URL:
    WordPress Username:
    WordPress Password:
    Pramod Patel
  5. marketinggal
    Thank you, Pramod. The latest is that we cannot change the writing on the slider.
    Am sending you the info. So appreciate you looking into this.
  6. Pramod
    Pramod Guest
  7. marketinggal
    Hi Pramrod,
    Thanks for your reply. But please look at note below. There are major issues as far as the order that they are supposed to be in and where I had to put them on the slider settings in order for them to show how we wanted them to show.
    These are not correct as they should be. If you will see the order that they are showing in the slider, it is incorrect. I want the one that says second to be second, not fifth. Here is how they are showing: http://screencast-o-matic.com/watch/c2QqqAec3E. They are sliding in the right order only because I added them backwards after the first.
    This one, should be second slider (hence second) http://enterpriseriskstrategies.com/wp-content/uploads/2014/09/2second1.jpg and I have added it as the fifth slider in order for it to be shown second. And the heading should be:
    Analytical Benefit Solutions for Non-Concentric Benefit Integration
    It is in the right position only because I added it to the fifth position. Please see the PDF I have enclosed and this image that shows this description in the fifth slider.
    The third one should be http://enterpriseriskstrategies.com/wp-content/uploads/2014/09/3third1.jpg with the heading of: "Health & Welfare Product Procurement, Pricing and Placement" and it is uploaded it in the fourth position. Please see fourth slider info below. This should be the third slider and it works only because I added the picture and header to the fourth slider info.
    The fourth one should be http://enterpriseriskstrategies.com/wp-content/uploads/2014/09/4fourth.jpg and the heading should be Human Capital Data Integration to Facilitate Spend Recover. I had to put it in the "third" slider position in order for it to show fourth on the slider.
    And the information on the second slider is showing as the fifth slider. This is the picture: http://enterpriseriskstrategies.com/wp-content/uploads/2014/09/5fifth.jpg and the header is Collaborative Solutions for Comprehensive Benefit Alignment. Please look right below to see this.
    Hope this makes sense. Thank you.
  8. Pramod
    Pramod Guest
    I got it .Please download a fresh copy of theme and upload it.
    The files are correct but create this issues. It may be because of plugins.
    Try after deactivation of all plugin.
    Pramod
  9. marketinggal
    Just wanted you to know that it was our mistake. We had changed the scrolling arrows to be smaller and this is what messed up the theme. We went back to the original arrows, and then everything was fine. Thank you!
