Woodpecker Theme "comments off" on posts and italics followthrough
Discussion in 'InkThemes-Support Working Hours' started by gilpinfordwpwood, May 16, 2017.
  1. gilpinfordwpwood
    gilpinfordwpwood New Member
    Two queries.
    How do I remove "Comments Off" on my posts?
    How do I get italics to show up. In edit mode they are there, not when published.
  2. Naveen
    In order to hide the comments form, you need to paste the below custom CSS code in the Custom CSS field located under Dashboard->Appearance->Theme Options->Styling Settings
    #commentsbox {
    As far as the italics font style is concerned, please share the exact page URL here where you are not getting this.
    I will check and let you know the solution.
    Regards!
    Naveen Kolhe
