WP 5.6 upgrade - Affected "Hamburger" icon in mobile view
Discussion in 'Traffica WordPress Theme' started by garfie, Dec 30, 2020.
  1. garfie
    garfie Member
    I've upgraded WordPress to 5.6 and my "hamburger" (menu graphic) on mobile view has gone from the normal 3 bars to a single bar. It still works as you would expect, but it's not showing the middle and lower bar. I have tested this with Firefox, Safari, & Google browsers and getting the exact same results. The phones we tested it with are Iphones 5s, 6s and Xs.
    Any idea what might be causing this?
    Are there any other issues with WP 5.6 that affect Traffica Pro?
    Thanks in advance!
    Garfie
  2. akbar92
    Greeting from InkThemes,
    We need WordPress admin credentials to figure out the issue.
    WordPress Website URL: -
    WordPress Username: -
    WordPress Password: -
    Akbar
  3. garfie
    garfie Member
    I have sent the email as requested - Thank You!
  4. akbar92
    We have successfully received your credentials and is being forwarded to our developers, we will get back to you with a positive response ASAP.
    Warm Regards!
    Akbar
