Hi, when I try to use WP Forms on the frontpage, they don't work. It just shows the "[wpforms id="35"]" although they do work on other pages. How can I fix this please?
Hi, Hope you are doing good but try this shortcode for the frontpage: Code: <?php echo do_shortcode("[wpforms id='35']"); ?> And use below shortcode for the post and other pages: Code: [wpforms id="35"] Hope this helps...! Regards, Akbar InkThemes.com
Many thanks for the reply where do I put the <?php echo do_shortcode("[wpforms id='35']"); ?> please. I have put it in the code but it's not working, so I must be doing it wrong.
Hello, Will you please share some screenshots of the concerned areas of your site. So that we can tell you accordingly, Looking forward to hearing from you soon. Thanks & Regards! Akbar InkThemes.com PS: You can create your screenshots using screenpresso (http://www.screenpresso.com).
For some reason, this forum won't allow me to upload an image you can find my front page here and you can see its just displaying the webform code instead of the form http://www.lifeunlimitedgroup.com/ I have posted the code you stated into the tet of the home page and then used the webform code at the bottom I am not sure what I am doing wrong
Hi, We need WordPress admin credentials to figure out the issue. Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will try to fix your issue. Regards, Akbar InkThemes.com
You are most Welcome! Hope your issues have been resolved. Just need a quick feedback from your end, Please check below link. https://goo.gl/forms/LNDY7bci4UEsHkG42 Warm Regards! Akbar InkThemes.com
