WP-POOL in Colorway Pro
Discussion in 'ColorWay WordPress Theme' started by mazoppei, Jun 27, 2013.
  1. mazoppei
    mazoppei New Member
    I used to have Colorway theme and uptaded to Colorway Theme Pro. In the process, my Pool´s Page (i used wp-pool plugin) is working, but the answers are all spread the page and the mark boxes are too (picture atached). Is there a way to fix that? Should i use another pluin for this version?
    Please help!
    Our theme is compatible with almost all the plugin but there are multiple plugins available in WordPress therefore it is not possible to check every plugin with the theme, You can search alternative of that plugin it may work fine with the theme.
  3. mazoppei
    mazoppei New Member
    Thank you Gourav! I have just got what the issue was...i configured the template to fullwidth and it came back to normal again...
