Hi, When I click on the xml sitemap link. I get sent to this page: https://www.upholsterycleaningdoncaster.co.uk/sitemap_index.xml Can you help me resolve this please.
You are most Welcome! Always feel free to ask your queries at our support forum: http://inkthemes.com/community/ and at our email [email protected] We would be glad to assist you... Have a nice day! Thanks & Regards! Akbar InkThemes.com
Hi, I am having the same problem on another site. It is sending me here: https://www.ovencleanerdoncaster.co.uk/sitemap_index.xml I can't remember how you resolved it last time. Thank you.
Hi, Greeting from InkThemes, We need WordPress admin credentials to figure out the issue. Kindly send the below-mentioned credential details at [email protected] along with the thread link. WordPress Website URL: - WordPress Username: - WordPress Password: - We will try to fix your issue. Regards, Akbar InkThemes.com
Hi Akbar, I got your email about deactivating the Yoast plug in. Thank you. can you tell me how to find my site maps now, so that I can load them up to google search console. Thanks, Paul.
Please check this link: https://ovencleanerrotherham.co.uk/sitemap_index.xml/ Regards, Akbar InkThemes.com
Hello, It seems like the XML sitemap is not properly added into the website. Regards, Akbar InkThemes.com
I'm sorry Akbar, I don't understand what you are trying to explain. I have about 12 active Appointway sites running. Most are working fine with Yoast installed, and site maps accessible. Some will not work, with Yoast installed, or not. I have read here a lot about this. It does not seem to make any sense to people suffering from this. The URL you gave me: https://www.ovencleanerrotherham.co.uk/sitemap_index.xml/ Just send's me to a useless ' This is somewhat embarrassing, isn’t it?' Page. You say to 'Try to re-create the file'. How? If had this kind of knowledge, I wouldn't be running wordpress sites. I use this theme because for some years it worked all the time.
Hello Paul, Last time I had also deactivated the plugin to fix this issue. You are requested to contact the plugin author in this regard. If they will unable to fix the issue then just let us know. We will do the needful. Regards, Akbar InkThemes.com
