Yoast Headings not working
Discussion in 'BlackBird WordPress Theme' started by lauramts123, Jun 14, 2014.
  1. lauramts123
    lauramts123 New Member
    1084 Lancaster Avenue Bryn Mawr, PA 19010
    My website is www.mainlinecounselingpartners.com. I have installed the yoast seo program. Even though I type in my meta descriptions, google still uses first line of text. Please advise.
    I think theme meta description conflicting with plugins description.
    You can remove default meta description from "header.php" file.
    Check image for reference.
    Nitesh Raghuwanshi
  3. lauramts123
    Thank you for your response. I am not a programmer so can you give more information about how I can find the header php file?
  4. Gourav
    Go to
    Appearance > Editor
    and search(ctrl+f) header.php there and open it.
    Gourav Shrivastava
  5. lauramts123
    Thank you so much, but I made the change above and it doesn't seem to be working
  6. Nitesh
  7. Nitesh
    Whatever description you add for home page will display as a meta description.
    Please check image attached. Which is showing description you have added in the
    Dashboard > SEO > Titles & Metas > Home > editing the front page itself
    Nitesh Raghuwanshi
